Remote codes for internal adj. on Toshiba Model # 36A61
6 posts / 0 new
musicman 4
I would like to find out what the remote code numbers are for internal adj. such as Screen. Drive, Vert, Horz. Etc on a Toshiba Model #36A61   chassis # TAC 0112. Thanks for any info. MSMN4.
Kdog
At present the TV has good
At present the TV has good Red @ Green. Can see that Blue is there but on the weak side. If this TV has remote Codes to inc Blue screen or Drive Voltages this will save me the trouble to remove back to do this.
        Will appreciate any info.    Thanks
Without a service manual,
Without a service manual, going into the service mode is a scary thing.  Remeber to always write down the codes before you proceed and do not change anything if you do not know what it is.  I take no responsibility if you hose nyour TV set.  Toshiba happens to be a set that is not easy to do.. Go here and READ READ READ before you go ahead with these alighnments.  Good Luck, and let us know how you made out.
Kdog
Larry, sent another reply,
Larry, sent another reply, don`t see it on the board so trying again.
   I went into service Mode and noticed I can make Adjusments on about everything except the Blue. Doesn,t seem to inc or dec. Like i say the skin tones are pretty close but lacking an inc on the blue. I did not go down to the Theater or Normal area below the upper service mode. I notice there are Blue, Green and etc in those areas also but wanted to see if you think this would do any good. Another question is, are there any Blue Screen or Blue Drive Pots on board at back of Pic tube?  Thanks for any info.
Kdog
musicman 4 said: Larry, sent
musicman 4 said: Larry, sent another reply, don`t see it on the board so trying again.    I went into service Mode and noticed I can make Adjusments on about everything except the Blue. Doesn,t seem to inc or dec. Like i say the skin tones are pretty close but lacking an inc on the blue. I did not go down to the Theater or Normal area below the upper service mode. I notice there are Blue, Green and etc in those areas also but wanted to see if you think this would do any good. Another question is, are there any Blue Screen or Blue Drive Pots on board at back of Pic tube?  Thanks for any info.
Did you get the service
Did you get the service manual my friend?   That would be in there.
