Need help with TV
6 posts / 0 new
android32
Need help with TV
The other day, my TV mysteriously broke on me. I was watching the TV for a couple of minutes, when all of a sudden, it shorts out (this has happened before with no negative long-term effects, or so I thought). I try turning the TV on, and the TV turns on, but only displays the little column in the center of the screen, the rest of the screen is black (you know how when you turn off a TV, there's that little white bar in the center of the screen that's the last to go away). I tried changing the TV to the DVD player, to the VCR, unplugged the cable, to no avail. Anybody have any solutions or things to try before I contemplate buying a new TV?
 (If there's a case similar to this on these forums, please link me to it)
Silva
You have a vertical fault
You have a vertical fault .need modle#.
Silva
Don't know that modlel and
Don't know that modlel and there's no info on it, this is a Wallmart stuff, but anyway it could be vertical IC.and bad caps also resistors, if know how that should be a easy fix. good luck.
MOtvGuy
Many Apex models weren't
Many Apex models weren't really servicable because APEX never provided service literature. That may be one of those models.
sop75
apex 2014at-dead tv ,measured
apex 2014at-dead tv ,measured  output of switchmode power supply.all ok but one.it is the 11 volt output  which now reads 2.4 volts.cannot find short causing this.dvd also dead.no schematic.
sop75
sop75
sop75
