Zenith R40W46F
woodbutcher
Zenith R40W46F
Hey Folks, My Lady Friend's son recently aquired a Zenith Rear Projection TV.  It formerly belonged to a friend of his. From the story I've been told, one of his friends buddies was playing with the remote and apparently somehow entered service mode.  I think the code was 5,6,7,8,enter or similar.  Anyway, sometime during his playing, he lost all picture.  I'm not sure if  he turned off the guns in the process but was wondering if there is a way to "reboot" the set.  My first inclination is no.  I'm thinking it would require having a like or similar set next to it and run through the service mode on one and enter the codes on the non-working set to be able to "see" what you were doing.  Any thoughts?
 Woodbutcher
  Factory fresh service menu
  Factory fresh service menu settings
VP 0F MODE 0
VP 1 OSD H POSITION 5
VP 2 AC ON 0 - (I'd stay away from this one)
VP 3 MSCOL 13
VP 4 POSHR 31
VP 5 POSVR 9
VP 6 RAMP 62
VP 7 GAMP 63
VP 8 BAMP 61
VP 0F MODE 1
VP 3 V-LIN 8
VP 4 S-CORR 7
VP 5 VPOS 26
VP 6 VSIZE 31
VP 7 H-POS 13
VP 8 HSIZE 22
VP 9 PINAMP 22
VP 10 U-CPIN 33
VP 11 L-CPIN 35
VP 12 TRAPEP 6
VP 13 EHTCOM 7
VP 14 AFCBOW 9
VP 15 AFCANG 6
VP 16 H MASK 0
VP 17 R-CUT 13
VP 18 G-CUT 8
VP 19 B-CUT 7
VP 20 R-DRV 38
VP 21 G-DRV 27
VP 22 B-DRV 23
VP 23 MSCOL 13
VP 24 POSHR 31
VP 25 POSVR 9
VP 26 RAMP 62
VP 27 GAMP 63
VP 28 BAMP 61
Most Zeniths are about the same.  try these and let me know if this helps.  Good luck, and let us know if you fix your set, as there could be a problem if these settings are reset and the set still does not work.
