I have a set I have been using for quite a while on cable.
I now want to move it to another site, which does not have cable. However, I can't seem to get it to respond. When I turn it on, it gets one channel with a lot of snow.
I tried to access menu, but it won't do it.
Any suggestions?
Feel free to respond to me at [email protected]
You need either to repair the tuner or get a new one. or the frequency of off the air signal is too weak. Also you have to change in the menu set up from cable to off the air.
You need the original remote to access the menu in this set. if you do not have one, see if you can borrow one from someone. if you have the original remote, go into the menu, then into setup and then into the channel programming guide, there you will see a selection for antenna or air/cable. Hilight the air or antenna feature.
