Can't Get Channels under 51
Shirley7
I have an older 25" GE television. The picture screen suddenly turned to snow and we discovered it will only show channels from 51 up. Using the menu button, we tried to autoprogram the other channels but it will only store the ones from 51 up. Help!
First try to unplug the TV
First try to unplug the TV set for 24 hours at least, and then do another auto program on the TV set.  if it still does not work, you most likley have a defective tuner, and from the age of the TV set, it wont be worth the couple of hundred bucks to replace it.  This should only be done by a trained tech.  Good Luck, and please let us know how you made out.
Shirley7
Thanks so very much for the
Thanks so very much for the advice!  The picture is so good on the channels over 51, I just needed to know what it might take to get the others back.  We changed the cable and actually switched the TV to a different room, but those tactics didn't work, so I'm happy to try unplugging it.  I'll let you know if I have any luck.
