hi can anyone help please i recently bought a new convergance panel for my thomson scenium rp tv model 44rw65us, i need the engineers code to enter the convergance set up thanks for any help
On the front off the TV set, with the set turned off, press and hold the Program - and the volume -. Some easy to get around menus in this set. I would, if I were you, try my best to get a service manual, as adjusting a service menu without the proper sequence can be very dangerous. Good Luck, and please let us know how you made out.
thanks for the help on the convergance there was a red blotch on the bottom of tv but when i change the convergance panel the blotch has gone, but didnt know how to set up the main convergance thanks to all
hi larry just as a matter of interest, this is the second thomson scenium i have bought , the other one just flashes on standbye does this mean the set is kapute
unfortunatley i dont have, larry ive just tried the code for the convergance that takes me to the normal set up for convergance, i guess i must need the engineers code to access the convergance
Dan, it depends on the chassis number. Its always good to have the entire manual but if you have any ideas, please share. IO have a somewhat amount of repair facts and tips, as we used to do alot od warranty work, and every set that came in, we wrote down the fault and what fixed it. Alot were common falures, like the older vertical problems with Toshiba TV set where the Two caps would need to be replaced.
Glad to hear you got it going. Happy Holidays
Most likley a problem in the sweep power supply or the horizontal sweep. Common problems for these.
ok larry my friend thanks for all the help a merry xmas to you and your family
If you have a manual on the set send or forward to me and we will see what we can do and if its worth fixing
You may want to look at this and see if it helps you any.
http://myweb.accessus.net/~090/how2ad...
Are both sets the same model? I'll look for the svc manual.
Larry, do you need the whole thing or part of it? Send me a quick note.
Thx
yes both sets are the same model
