larry,
i've tried replacing the rectifier diodes with no luck. all voltages read as they should even when i power down, but after an hour power down that c840 cap blows. this is driving me nuts. f802 reads as it should. i took off the casing to the startup relay and if i manually connect the relays, the set powers up fine, as long as i hold the relays together. the relay won't hold with c840 blown. any reason you think why that fucker keeps going bad?
wayney
