rca rtd207
jmatlock
rca rtd207
Does any one know why the rear speakers work on everything but the t.v. surround?
It's possible your surround
It's possible your surround setting for the TV input is defaulted to Stereo, so a simple mode switch would be all you need to do. If you have it set to Pro Logic, or another surround setting, you need to understand that most television shows do not use the rear channels much. Most television audio is voice, and this will be routed to the center speaker in your surround setup.
