Toshiba Projection screen model tp5288j no picture but the on and off button light is on when u plug it in, on and off button does not work.
big ray
No picture but the on and off button light is on when you plug it in the on and off button does not work.
This is avery hard call my
This is avery hard call my freind, as this could be just about anything in the power supply and or the sweep section of the TV set.  Most of the time though, there is a capacitor or regulator componet that goes bad in these sets. If you have no serviceing know how, please play it safe and call in a pro to assist you in this repair. If you know how to follow a schematic and now how to solder on a printed circuit board, there is a place that sells service kits for all differant troubles with Toshiba TV sets.  Im not saying that the kits work all the time but I would say at least 80% of the time ,I got a kit, it fixed the problem.
Here is the link: http://www.tritronicsinc.com/telamatics/toshiba.html and heres the link to go to when you find the part you need  http://www.wehaveparts.com/ Just scroll down till you see your chassis number or your model and look at the symptom.  Good Luck and please let us know how you made out.
