I found this from a major manufacturer of LCD products. Hope this helps. And never press hard on the screens surface.
IBM "The users guides for IBM Flatscreen TFT panels suggest the following: Caring for your IBM Monitor:
Be sure to turn off the power before you perform any maintenance on the monitor. Clean your monitor as follows:
Gently wipe the covers and the screen with a soft cloth. Remove finger marks and grease with a damp cloth and mild detergent; do not use solvents or abrasives. Never apply detergent or other liquid directly to the screen. Dampen the cloth and then wipe. Never use flammable cleaning material to clean your IBM monitor or any other electrical apparatus."
IBM
We also have an article on this topic here at TechLore: How to Clean Your TV Screen
Matt, the link does not work. It says the page cannot be found.
Hmmm. The link seems to be working for me. Can you double check? If it doesn't work, can you paste the URL of the page it takes you to?
