TV not responding to remote control
9 posts / 0 new
Titen
I have a Toshiba Flat screen TV/DVD/VCR combo that slowly stopped responding to the remote control.  I have tried replacing the batteries and also tried a brand new remote...no success.  Any suggestions?
Was it an original remote you
Was it an original remote you tryed, or a universal type of remote?
Titen
Larry Dillon said:
Yes, I tried the original remote as well as a brand new universal remote.  I tested the universal remote on another TV so I know it works for sure.  Any suggestions?
Silva
Does it respond to  tv
Does it respond to  tv buttons If so you have to check the IR circuit.
Most likly you have a remote
Most likly you have a remote sensor problem.  This is something thats buried way up front of the set in back of the plastic cabinet.  Not an easy thing to get to.  its the sensor or the power supply running to the sensor, or a bad connection between the sensor and the microprocessor.
Titen
What and where is the IR
What and where is the IR circuit?  The TV responds to its own buttons.  So I will need to take the TV to a professional correct?
Thanks for the help
Unless you know about solid
Unless you know about solid state repairs on printed circuit boards, as well as have an ocilliscope to trace the data from the sensor, then i would highly advise on taking this set into a pro.
Titen
Do you think it would be
Do you think it would be better to just buy a new TV.  Any ideas on cost for repair?
Its a hard call on replaceing
Its a hard call on replaceing something.  This may help you, with this article ,well written by the editor of this site.  Check it out.
http://www.techlore.com/article/10602/How-to-Determine-if-you-Should-Repair-a-Broken-Device/
