green bulb problem
11 posts / 0 new
faulkyouto
green bulb problem
my  brother in laws sony videoscope xbr model# KP53XBR45  a problem
when i cover the green the red and blue are fine otherwise in the corners there is a pinkish color any suggestions would be helpful
Im really not sure what your
Im really not sure what your discribing,  Please be a little more detailed in your disciption.  Is there a spot of pinkish in the corner when you do not cover the red?  is the pinkisk there all the time.  Why are you covering the red?  Is it a 3 d effect your talking about?
faulkyouto
sorry  without doing anything
sorry  without doing anything there are pinkish colors in the corner and kinda of looks like i dont know a pink with a green shadow but if i cover the green the red and blue align fine
i hope that is  a better idea of what is going on PS someone told it may be convergence?
Oh so it looks almost like
Oh so it looks almost like the colors are out of alighnment? Kind of like a 3 d effect? Should have figured! This sounds like the typical convergence fault that happens on almost every tube type projection set ever made. There are two STK types of large stand up IC's that are mounted on a large metal heat sink that has to be replace. These are not replaceable by the user, unless you have electronics serviceing know how and know how to solder. there could also be a few small resistors that go bad as well with these IC's. If you have no solid state TV repair experience, Please play it safe and call in a pro to assist you with this repair. Good Luck, and please let us know how you made out.
faulkyouto
do you know where I can get a
do you know where I can get a schematic if not thanks again for all your help most enlightend one
chad
Well Heck! Thats an easy one
Well Heck! Thats an easy one bud.  Go HERE and download one for about 24 bucks.
faulkyouto
well thanks a bunch buddy  i'
well thanks a bunch buddy  i''ll let you know how it turns out
faulkyouto
is it still the convergence
is it still the convergence when the right side of the screen is warped
If you see color lines
If you see color lines aticking out of the pictures outline yes, kinda like a 3D effect.
easytouch
sounds like a simple pot adj.
sounds like a simple pot adj. on the green from the flyback.
easytouch what are you
easytouch what are you talking about man?????
Larry Dillon.
