Television colour problems
6 posts / 0 new
valcum
SWITCHED ON MY TV TODAY, SOMETHING HAS HAPPENED TO THE COLOUR, EVERYONE LOOKS LIKE THE INCREDIBLE HULK. TRIED TO CHANGE COLOUR BALANCE IN MENU - NOTHING, THEN TRIED PLAYING A DVD, SAME EVERYONE GREEN. DOES ANYONE KNOW WHAT CAUSES THIS, IS IT AN ECONOMICAL REPAIR, OR SHOULD I BIN THE TV. THANKS FOR ANY HELP.
It sounds like your missing
It sounds like your missing one of the colors.   What type Of TV set is this?  Is it a direct veiw? a projection set?  Please when asking for help, include more info on the TV and or device as we will be more then happy to assist you with your problem if we can.
valcum
HI, LARRY, IT'S A BEKO 14.2
HI, LARRY, IT'S A BEKO 14.2 SERIES WIDE SCREEN DIRECT VIEW, THANKS, VALERIE.
Valerie!, LOLĀ  What model
Valerie!, LOL  What model number?
valcum
:) Sorry Larry, I'm a bit of
:) Sorry Larry, I'm a bit of a "numptie" when I'm dealing with technology!
The model number is 284216WNS, there is an NR before the number, but I've been reliably informed by a 10 year old that it means number. :)
Thanks again.
The specs on this set:
Screen Type Flat Screen
Diagonal Screen Size 28 inch
Display Capabilities
Aspect Ratio 16:9 • 4:3 Enhanced
Built-in Tuner NTSC
Remote Control
Remote Control Standard
Illuminated Remote Non-Illuminated
Image Quality
Adjustable Color Temp. Without Adjustable Color Temperature
Audio Features
Subwoofer Without Subwoofer
Audio Type Stereo
SAP / MTS Stereo SAP / MTS Stereo
Technical Features
Picture in Picture Without PIP
Parental Control Proprietary
Sleep Timer With Sleep Timer
Screen Text
Closed Caption on Mute Without Closed Caption On Mute
Dimensions
Width 70.7 cm
Depth 48.7 cm
Height 50.7 cm
Weight 33.7 kg
33.7 kilogram = 74.295 782 356 pound so I am assuming this set is a picture tube type set because of the weight of it.  Its all green because of a RGB driver fault, bad connection on the Picture tube socket or drive board, or at worst, the picture tube is bad.  This is not a repair a user should attempt, as there are no user replaceable arts inside this set.  Have it checked out by a repair shop.  Good Luck, and please let us know if we can assist you in any other way and or how you made out with this set.
