We have a 50" Fitjitsu Plasma TV, we are connected thru direct TV. We get sound on our TV and no pictures. The red standby light stays on flashing. We tried to reset the direct tv receiver, unplugged the TV etc, and still no picture.
After unplugging and replugging a hazzy, fuzzy colored picture appears for a few seconds and then screen goes blank and standby light flashes again.
Please help!!!!!!!!!!!!! ;-(
Thank you,
Barb
Barb, Thats an indication when the light flashes that the bulb is bad in the light engine. Im not sure if thats part of the three year warranty or not, you would need to look that up in the owners manual, or call the location where you purchased the set. Good Luck, and please keep us informed of your progress.
Thank you Larry. We do have an extended warranty (thru Good guys ;-/) and they will be out on Wednesday to check it out. I will keep you posted.
Barb
Thank you Barb. Smart choice with the extended warranty! Have you see this yet? http://www.techlore.com/article/14812/ Lots of great stuff here.
Thanks for the info, I haven't seen this before......... I guess it's worth having extended warranty if you have to use it ;-).
Barb
If that's a Plasma set it won't have an engine. Possible problems with that include a bad main board, one of the Sustain boards, power supply or at worst, a bad plasma panel. You'll need a servicer to look at it.
Motvguy is correct. I thought it was a plasma projection, but its not. Under warranty anywho. Problems with these sustain boards I see after reading a few things about this set.
Thanks again, I guess I will find out Wednesday that is when the
service guy comes out. How annoying not having your big screen on
game day. (Niner fans ;-).....................
Barb
