BUSH LCD32TV22HD TV SURROUND SOUND CONNECTION
11 posts / 0 new
herby stew
HI can anybody help I just bought an lcd 32inch tv which has 2scart inputs but only 2 o/p phono sockets.  I use Sony audio/video contrl unit type STR K740P TO OBTAIN SURROUND SOUND. I cannot get the tv video to sync with the Sony sound.  Any suggestions as to how I can solve the problem???
thanks stew
herby stew
views have been expressed but
views have been expressed but i cannot access them Please help stew
herby stew
Please email me at herbys12
Please email me at [email protected]  as icannot get into system to read any of your views.
thank you stew
To clear up some confusion,
To clear up some confusion, you'll see both posts and views represented on the forums home page. The number of views indicates how many times a particular forum thread has been viewed (looked at) by someone, not necessarily that they responded. The number of posts indicates how many individual comments the thread contains.
TechLore does not hide forum or article content from our members. If someone else responds to your question, you'll be able to see their comments and respond in kind.
Be patient, sometimes it can take some time for the right person to come along who may be able to answer your question. Hang in there!
herby stew, what do you mean
herby stew, what do you mean by O/P and phono outputs?  Do you mean output and RCA type outputs?  And please explain sync with the sound?  Maybe we use differant tech terms?
herby stew
hi larry,by sync I mean that
hi larry,by sync I mean that the sound obtained via my sony surround system does not synchronise with the lip movements shown on the bush tv, I find that this only happens when the tv is operating in its digital mode. The 2phono  outputs are referred to as audio line outputs. By o/p is shorthand for output.  Hope this answers your question await your reply.  stew
Page 9 of the Surround sound
Page 9 of the Surround sound is the typical hook up. Did you say there was no video input jack thats an RCA type? If you do not there is an inexpensive way to do this. It available at http://www.nexxia.co.uk/Hi-Fi&TVacces...   Click on the first one on the upper left hand corner as I think thats the one you want.  Also then you can connect up the equipment just like it explains on page 9 of your surround sound user manual. If you dont have one for your Sony get one here http://esupport.sony.com/US/perl/mode... Good Luck and please let us know how you made out.
herby stew
hi again Larry I should have
hi again Larry I should have mentioned I had tried using scart to rca adaptor to connect to my sourround sound and found that the sound produced was associated with tv analog signal channels and not the digital channels.  I have just discovered that the sound output from the 2 audio RCA output jacks is also only associated with the analogue channels hence there appears to be no audio output available for the digital channels my previouse observations were obtained when I was viewing the same channel no for digital and analogue.  I shall have to look again at configuration for sound on this tv but not too hopeful. if I find out more will let you know.   Sorry this is so long but I want to give all the facts.   Stewart
herby stew
Hi matt Thank you for your
Hi matt Thank you for your information regarding forum proceedure,it is all very clear now.  Stew
You could look into an input
You could look into an input adaptor for the scarts and an optical or digital output to go to the stereo
herby stew
Thanks to every one for there
Thanks to every one for there help, I  have now got the answer from Bush help line. I had to get into the menu for aux connections, change sound from tv to dti. It worked as I can now get the digital  sound output from the tv through my surrend sound system.     Stewart
