INHD Tune Up
Brandon C.
INHD Tune Up
I see that INHD runs a program called INHD Tune Up, to help calibrate your set.  From their Synopsis:
"INHD's High Definition Television set up feature provides a series of
patterns that will enable you to set up your HDTV."
Anyone tried it out yet?
It looks like it is scheduled for 11/12 and 11/19 at 7:00 AM (Exact time depending on your time zone) I have it set to record, but am wondering if anyone has tried it and found it of value.
No I never saw how well those
No I never saw how well those are but we have something on that HERE.  You should check mit out.  I know it has helped me and im sure several others.  And then theres alot more here on HDTV.  Have a look around and enjoy yourself.
Guest (not verified)
I use the Video essentials
I use the Video essentials DVD already. Works fine, but my set will allow individual adjustments for each input. So I figured that I would copy the DVD setup to the HD cable input setup, then check it with the INHD video, for fine tuning.
Also, might be something that could record on DVR, sling to computer, then adjust video on monitor. Might be fun to try, anyway.
