Blown TV
6 posts / 0 new
megawatt
Blown TV
I"m in Iraq where the power is 220volts 50 HZ. My 120volt tv. was plugged in and now it doesn't work. The fuse is still good, can it be fixed?
Can you tell us what brand of
Can you tell us what brand of TV set as well as the model please?
megawatt
It's a Sharps Model#27F541
It's a Sharps Model#27F541 Serial# A508894525.
megawatt
Larry Dillon said: Can you
Larry Dillon said: Can you tell us what brand of TV set as well as the model please?
It's a Sharps Model # 27F541  Serial #A508894525
recordco
i am asking basically the
i am asking basically the same question about my sony tv, but basically when you run the higher volts, ,there is a 'fuse' somewhere, ( i am waiting for a techie to tell me how to reset) . sometimes its on the board. on my computer is a small button about the size of a pinhead, and this itself is a mini computer that saves the info bout what is good and no good, and if its getting too many volts (or worse too little) it shuts it all down . not recomended for avg. person to do though, everything must be shut down etc, you could get burned! or do it wrong and suffer.....my reccomendation , if you cant fix it, get a laptop  and add a tv card...that way you can take it everywhere. : )
- tom
Sorry Megawatt, to answer
Sorry Megawatt, to answer your question, It could be as simple as a fuse thats blown, or a major blow-out such as the Printed curcuit board could be burned . Also most likly it took out whats called a surge resistor or current limiter resistor. UsuallY, those are a big rectangle looking about 3 to 5 inches long and about .5"x.5". They are mostly white or light brown in color and may have a low value to them, such as 1 ohm all the way up to 6 to 10 ohm. Hope this helps. Let us know how you worked this out. Good Luck
