Pioneer DV-C505 it will play some dunrt dvds but not all i burn them all th same way. when i put a dvd in sometimes it just shows colored dots it has sound . please help
It seems you may have a digital to analog converter problem. Or if your using a scart or HDMI cable, you could have a problem with the cables or the connection jack as these are not supported very well on the printed circuit boards. If its running through regular video plug(yellow) thr a differant input or plug. If your running an optical plug or coax output. try a new plug or sub to another output on the pioneer. If all outputs work the same then there is a problem for sure in the D-A converter and If you want can most likly have it repaired, but will probably cost you more then it is worth. Good Luck and please let us know how you made out.
