I have a GE Spacemaker model 75295 under cabinet clock radio and cd player.
The CD player works (the disk spins) but it does not play. It has worked up to the last month. The disk spins, "CD" blinks and then will shortly display a "nd" - no disk message so its not recognizing the cd.
How do I go about finding out what's causing this and any suggestions how to fix?
Have you tryed a lens cleaner disc yet?? This link is for combos DVD but if you can get the case off your unit its the same procedure to clean the lens.
http://www.techlore.com/article/14550/ If this does not help you im afraid to say to you that it is most likly not worth fixing. Good Luck and please let us know how you made out.
