Look first in the sweep power supply for bulging or split capacitors. this is a common problem with these sets. If you do not see anything out of the ordinary, you will need to get a schematic and trouble shoot first the horizontal sweep circuit. if you have a schematic I can assit you if I get a copy of the it. If you have no electronic repair experience please do not experiment with this TV as it is very dangerous, as there is extremly high voltage inside of them. Please call in a trained tech to assist you. Good Luck and let us know what you did to get the set working again.
I tried s to obtain a service manual but could not find one any suggestions
