No my friend, im afraid theres not. These sets are "famous" for the High Voltage transformer, also known as a flyback, to go bad. Also sometimes it is simply bad solder connections on the driver transformer or the flyback. If you have no electronic circuit experience, this is not the set to experiment with. It has several places that High Voltage is stored in even after it has been left unplugged for a while. if you have any type of serviceing experience, you will need to get a schematic diagram and start checking the front end power supply. If you do nort please seek out a trained tech to assist you with this repair as there are no user replaceable parts inside of this set.. Let us know how you made out please. good Luck
