Remote Control Malfunction
4 posts / 0 new
gkane2201
None of the remote controls are working on my Panasonic Tau TV.  I have a Directv, original Panasonic and a Harmony 676.  I have tried repeatedly to reprogram the Directv and Harmony w/no succsess.  all have new batteries.  This happened overnight, with no advanced warning.  Any suggestions.  BTW the TV is 14 months old model #CT-34WX15.
THANKS
Have you tryed to unplug the
Have you tryed to unplug the TV set for 12 to 24 hours yet?  It could be a microprocessor problem that needs to be reset.  If this does not work, I would say you have a problem with the remote sensor assy., or a connection from the sensor going to the micro., or the micro. itself could be bad.  Let us know what you found please, and Good Luck
gkane2201
i left the set unpluged last
i left the set unpluged last night.  total time ewas 7 hours.  should i try for a full 24 hours?
Yes, you should try at least
Yes, you should try at least 12 to 24 hours first before calling out a repair person or taking the set into the shop.
