I have a 26" Samsung LCD Tv...i believe the model number is LNR268W. Anytime i go to watch a DVD thats a widescreen the bars remain no matter what. When i put the TV in Widescreen mode it just stretches the picture out, and the bars remain. (So its like the DVD player still thinks its in the TV 4:3 format)
The DVD player is hooked up through an S video connection. I'm thinking the problem maybe the DVD player. Its a cheap APEX not sure what the model # is (I'm at work so i'm trying to go off memory).
If anyone can confirm that this could be the problem or might know what the problem is I would appreciate the help. Also if you need more information i will do the best i can to give you what you would need.
These two articles should answer all your questions about setting up your DVD player for widescreen TVs, and helping you understand how different aspect ratios should look when properly set up.
How various DVD aspect ratios will appear on your TV screen
How To Configure Your DVD Player For a Widescreen TV
