Hello,
I have a 6 yr old mitsubishi hd tv. I believe it is 47 inches. once in a while the picture will turn green for a few seconds. You can still see the picture, but it looks green. It then returns to normal. Any Idea what could be causing this?
Ray
Does the Picture have a green hue all over or does the picture go away with a bright green screen?
Ok, you have a drive problem or the crt(green) is over driving because of a bad connection on the crt socket. A common problem on Mitsu. If your not a tech, its not a good Idea for you to be experimenting inside this set because of the high voltage involved with the CRT socket. This repair should be recifyed in the home and at a reasonable cost UNLESS the problem turns out to be an intermittant picture tube.
No problem. And Please let us know if you got it fixed and what it took or what you did like replace the set or had it fixed. Thanks
