Please help
I have just tried to program my sky+ remote to work my Thomson t.v, only problem is now my t.v has turned off and won't come back on. The standby light is flashing on and off. I have tried unpluging the t.v and I have tried leaving it on, but still no luck. Don't know what to do...got 5 kids wanting to watch t.v and a t.v that just won't work.
HELP
Will the set come on when the front panel button is pressed?. If not theres a problem with the TV set and the remote did not make the set stop working.
The front panel button still works to put the power to the t.v but all that happens is the standby light (on the button) keeps flashing on and off when the button is pressed on. The t.v was working fine until I put in the code on the sky+ remote....then the t.v just turned off and won't come back on, not really sure what to do, I have talked to sky and they don't know either. Seems a bit strange that the t.v set was working fine right before programing the remote and that it turned its self of straight after.
Just a coincidince?? Could be.. Have you tryed yet to unplug it overnight like for between 12 to 24 hours?
Yep this happend over the weekend..tried one night with it off at the plug tried again the next day leaving it on. Still no luck and i'm getting fed up of it flashing at me!!!!
Yep it sounds like a breakdown. Sorry to have to inform you of this but it just happened to break down at the same time you pushed the remote or it happened when you turned off the set, and then tryed to turn it back on with the front panel button.. this is when alot of sets fail, when they are first turned on. Sorry you, it seems, are going to need to call in a service person to repair this or give you an estimate. let us know what you did or what it took to get this set back up again if you have it repaired. Good Luck
Thanks Larry......Looks like i'm going to have to spend money now
I will let you know what happens.
Thanks again
Im so sorry Lena! Let me know what your told, when you get an estimate, as maybe I can assist you so you do not get ripped off?
