Samsung television ttb2012 won't turn on
Techtard
My 1993 samsung television ttb2012 won't turn on when the power button
is pushed... though the red light inside the power button will
blink/flash for awhile. I use the tv to watch movies through VCR and
DVD players. It was working fine, shut off properly after use, then
one week later I tried to again turn it on. On this model, there is no
keypad to access any controls other than power, volume, and channels.
The original remote hasn't worked for a long time. Could this have to
do with needing to access other controls through a remote? Thank you
in advance for your assistance... Techtard
Memo Torres
Check power supply regulator,
Check power supply regulator, horizontal transistor, fly back 135Volts, swithching circuit
Techtard
Thank you Memo...  I'll do
Thank you Memo...  I'll do what I can, but I wish I had a better grasp of the technical language and how I might identify and test these parts.  I was hoping it would be as simple as getting a new remote.  I guess it isn't as simple as I had hoped.
