My C drive is almost full. I need to know what I need to do other than deleting programs. Is there a way to clean it up without removing programs I have installed or must I buy a larger C-drive.
you can delete the programs that you dont use. on "Fix it utilities6" by vcom has a program on their where you can delete stuff if it hasn't been used in a while also registry. you can allways get an external hard drive for your picture and videos
You do not say what size your current C drive is but a large harddrive these days is not very expensive. I have a 20 gig one just to run the OS and a 120gig one to store everything else. If you are using your hard drive to store videos etc did you know that a 1 1/2 video uses up aprox 16 gigs of hard drive space so you can fill an average hard drrive up in no time. I f you opt for a larger hard drive transfer everything except the OS and programs that you need to actually run the pc to it
You could also buy a larger hard drive and use a proggy called ghost to copy everything onto the hard drive and then. delete everything from the old hard drive and use that one for all your pictures and videos. I did mine that way and it works great. Let us know what you did and how you made out. Good Luck
