sharp lcd lc-20s1e power light
7 posts / 0 new
phil123
I wonder if anyone could help me,  my lcd tv just wont fire up the red power light is on but no picture when i press the remote, the power light flashes but it just wont come on. thanks phil
Some LCD sets won,t fire up
Some LCD sets won,t fire up if the main bulbs goes out.  Check in your owners manual under troubleshooting to check that.  If thats not the issue, theres a 3300MFD capacitor that goes bad in the main power supply.  Also this set has alot of bad connections in the power supply .  Last one I fixed, I had all sorts of intermittant problems, including not starting up most of the time.  If your not a tech PLEASE do not experiment inside the set, as there are no user replaceable parts, and there is line voltage present inside, and you could make things worse then they are if you mess with the circuits.. Get back to us and let us know what you found or what it took to fix the set. Good Luck and thanks for vistiting http://www.techlore.com save for future use.
phil123
Thanks for the info Larry ,i
Thanks for the info Larry ,i have checked the power supply and the pcb arround  it has melted, it's all black the pcb has a hole right through it will have to contact sharp and ask them is this a fire hazzard as no fuses had blown will let you know how i get on regards phil
phil123
Larry Dillon said: Oh MY! yes
Larry Dillon said: Oh MY! yes please do let us know..
Hi larry have just had a phone call to say the tv is us, will cost to much to repair so it,s of to the shops for a new lcd dont think it will be a sharp though phil
Oh No , So sorry to hear this
Oh No , So sorry to hear this.  I would not give up though with the UL people as well as the higher ups at Sharp.
Jonathan 9999
i need help with my big
i need help with my big screen tv it want show a picture can some one help me please it not  the power supplie hasnt gone out, but i need some tips how to fix it to repair this tv fast...
Jonathan, please include the
Jonathan, please include the make and model of this TV set your talking about, or is it the model at the top of this thread and how do you know the power supply is good?
