Sounds like the deflection yolk could have twisted and turned on you. Unplug the set, Open the back carefully. Look on the neck of the picture tube, see the coil of wire there? Carefully see if you can turn the coil in a direction that the wires dont get pulled on. CAREFULL!! Dont force it. If it wont move. put together the set and take it to a repair shop, as they will charge you a minimal charge Im sure. If your able to move it. Plug in the set and without touching anything, see if the Picture is properly adjusted. DO NOT TOUCH THE DEFLECTION YOLK WHILE THE SET IS ON!!! If the picture is upside down now or not right unplug and readjust till you get the picture correctly on the screen. If there seems to be a little discoloration on the screen, that should go away after a few times of turning on the set from being cold.. Let us know how you made out. Good Luck
