Sylvania 6420FE loss of audio
1 post / 0 new
gus
Looking for an assist. My 6420FE audio will quit approx 2 minutes after the set is turned on. However if you are using A/V Input 1 (DVD) or A/V Input 2 (VHS) the audio works correctly.  It only affects the Cable/Antenna jack on the back of the set.    Any ideas as to what component is the cause?
gus
