sudnly my camcorder stop working when ever i start to use i cant operate any thing and show all the time in disply press the reset., when i press reset after few second again start massage press reset. and i cant use zoom as well its stuck as well., please try to solve my problem my cam corder mac is panasonic NV-GS250.
PLEASE SEND ME A MAIL AS SOON AS POSSIBLE.,
Mr Patel, Your problem is that you have a tape stuck in the unit, if theres no Tape stuck, then there is a mechanical problem, where the mode switch is telling the microprocessor that the mechanism is is one mode, but the mechaniam is not really in that position, so the unit trys to move, but it gets jammed, because of the mechanism and goes into trouble mode so the unit tells you to reset. There is really nothing you can do, unless you have the proper tools and the training to work on these mechanical mechanisms. They can be tricky to alighn and adjust as even one little tooth off on the cam gear can cause loads of trouble. Its time to send the unit in or take to a local repair shop to have it checked out or theres a few online repair places that do nothing but camcorders and even gives you a free estimate. Check them out! http://www.videoonerepair.com/ Or http://www.videotech.com/ or
http://www.camcorderrepair.com/ Good Luck
