I have 2 ?'s for you . . . .
On some FM radio stations there is static (and it's set to the exact station), and I just need to move the antenna a bit, any suggestions on how to permanently make the static go away???
Next ?? . . . . this is a 5 CD playing machine, can I push a button somewhere to play selections from all 5 at a time without just playing the whole CD a song at a time??? On my old 3 Cd player I could push "random", does this have that option???
Thanks in advance . . .
Instead of using the built in antenna system you may need to get a powered or amplified antenna. Also a small outside antenna mounted on a small pole or the roof would work fine too. Now for the CD, some units have whats called a suffle feature on them. it would say if you did in the instucion manual or user manual. If the features not there then I dont know of anyway else to do it unless theres a programmable memory play settings like some of the pioneer dvd/cd players have. If you need a maual go here http://www.samsung.com/au/support/productsupport/download/index.aspx
Wish i could assit you more with this problem Good Luck
