amps
4 posts / 0 new
flash tattoo
flash tattoo's picture
amps
can I hook up a 2 channel and a 4 channel amp to the same car system?
Larry Dillon's picture
Yes you can as you can use
Yes you can as you can use whats called a y adaptor for the inputs if your head unit or radio only has 2 wires BUT most have a front set as well as a rear set. and make sure the amp. outputs are not connected to more then one speaker . Never share amps with the same speaker.  Make the grounds as short as possible and have a designated B+ wire for the B+ for the amps. depending on the current of each amp.  Good Luck
shadow_walker
shadow_walker's picture
ok im hooking up a sony
ok im hooking up a sony explode 600wt amp to a sony explode 1100wt 10" sub and the amp is showing it has power but the sub has no sound or isnt working what can i do to fix it
Jexx
Jexx's picture
This should help: http://www
This should help: http://www.techlore.com/article/14696/
Let me know.
