Hi all hope somone can help.
I bought the Sony KV-32CS70E when I was living in Spain. I have now moved to South Africa and just plugged my satalite system into TV only to find that there is a crackling noise coming over the sound. Picture is OK. I have just had the satalite engineer out to check the installation which he assures me is ok and said thier should be a setting called system which you can set to I instead of D/K or B/G which will sort it out in South Africa. It only toggles between D/K and B/G.
I do belive the sat is working because the sony is a bedroom tv the main lounge tv bought in SA works fine.
Is there anything I can do? Is he correct?
Cheers
Bon
