Sony DVP-NS50P says "cannot play this disc" on all discs!
9 posts / 0 new
justboog
My sony DVP-NS50P keeps giving the the message Cannot play this disc..and it gives me that on all discs...any suggestions?
sassyshirl
I HAVE THE SAME PROBLEM.
I HAVE THE SAME PROBLEM.  DISCS THAT PLAYED PREVIOUSLY NOW WILL NOT PLAY.  MY PLAYER JUST KEEPS SHOWING "CANNOT PLAY DISC"!
I HAVE A SONY DVP-NS425P.  ANY SUGGESTIONS.............HOW DID YOU CORRECT YOUR PROBLEM?
Read this article: http://www
ron mayers
I have a polaroid PDM 2727
I have a polaroid PDM 2727 dual screen portable dvd unit that has had excellent treatment, never left in the heat and had approx. 50 hrs. on it. Lens is clean. When you insert a dvd it tries to turn (approx. 1/8th)of 1 revolution and makes a ticking noise as it displays loading disc on a blue screen. In 5 seconds or so it then displays (no disc) still on a blue screen. Have ordered a new player already since warranty is up, but would like to try to fix this one. Any ideas? I'm stumped! thanks, ron
bumble
My kids have the DVP-FX750
My kids have the DVP-FX750 for use on car rides. One was giving the message "Cannot play this disc". What worked in the end --- I took a glasses cleaning cloth with nothing on it, and gently rubbed the lens of the DVD player. Not sure if I cleaned the lens or re-positioned it (if it was out of correct position). The lens carriage unit did bob up and down, left and right slightly (as I believe it is attached with springs). In any case, and to my surprise after having done this, the player played a CD and a DVD just fine.
Hope it helps!
DavidWJohnson
I have (had) a Sony DVP-NS70H
I have (had) a Sony DVP-NS70H.
"Cannot play this disc."
I tried everything.
I threw this Sony DVD player in the garbage.
I will never again buy Sony.
All products from Samsung are superior.
mady
I have a sony dvp-fx730, all
I have a sony dvp-fx730, all the disc that i put can't play but that i already put that before and its playing..but now it can't
charles henry
Manualy move the traverse
Manualy move the traverse mechanism. The laser sits on it. Push it and you will feel it jumping the gears. Once its at the end, put a dvd in and wait for it to load. It will play. I do this to my sony dvpfx750. These gadgets break down i guess. Well thats my fix. At least you can still play it.
Melissacabrera
I am having the same problem
I am having the same problem with my Sony DVD player, it was working fine then when I put in a movie after watching a movie it started saying cannot play disc I tried the DVD that I just watched and it says the same. I went to the link that you provided and it says page cannot be found.
