Help - Mitsubshi TV set for home theatre. Trying to change back to "normal" TV settings but menu steps say to press cancel button. Remote has no cancel button.... what to do????
original remote - unfortunately I can't find the model number of TV - probably on back, but it is old and very heavy, can't move it alone. I am simply trying to remove the home theatre setting as I have no home theatre and the TV isn't working with this setting turned on. This remote has no cancel button - nor can I find one on the TV controls. In order to change the home theatre setting to off the instructions say to press the cancel button.
Are you using the remote that came with the TV?
What is the model number of the set?
What exactly do you mean by "trying to change back to 'normal' TV settings"? Can you be more specific? Maybe there is a work-around.
