I bought this system about 1year ago and it worked fine. Until one day it started to play and when I went to turn up the volume I quit playing audio. The player was playing. The volume knob numbers on the screen were the higher the number the lower the volume the lower the number the higher the volume. But it would go from 83 decibles and when it gets to about 50 it stops playing sound. I would hate to throw it away since I just need sound but do you think it would be cheaper to just buy another or try to have it fixed.thanks Jeremy
Check your speaker wire connections on both the speakers and on the back of the receiver. The positive and negative leads on one of the connections may be slightly touching, which would cause the kind of behavior you're describing.
Give it a look and post back.
Unit will not play dvd's or cd's. Shows reading until disc finally stops.
unit shows reading and will not play disc(sa-ht75) i can also here the clicking.
Hi there,
Does anyone have a Manual for the Panasonic SAHT75 5.1 Sourrond Sound Home Theatre System??
If so, any chance you could email me a copy..
Would be much appreciated..
Laurina
Hi Laurina
check the link below
http://www.retrevo.com/support/Panasonic-SA-HT75-Home-Theater-Systems-ma...
