RCA TV 27V520T...Shuts Down....
12 posts / 0 new
vic6kar
Friends:
Hi,Yes we are working on a 27V520T Rca TV,and this one keep shut in down,Any suggestion,Please?
bertw
I am having the same trouble,
I am having the same trouble, and would appreciate any suggestions.  It turns on, then immediately shuts down.  member bethjohn
The TechLore Team
I have similar problems with
I have similar problems with both my RCA 32-inch and a Philips 20-inch.   Neither TV is working and both began shutting off and turning back on at short intervals 18 to 20 months after purchase.
designerman
I have a 36" RCA with the
I have a 36" RCA with the same problem.  It belonged to my parents and a few years ago they spent $200 to have it fixed.  The problem is back and it's not worth the $200, given the age of the TV.  But after a while of turning off and then back on the TV remains on and the picture is quite nice so I'd love to find and fix the problem myself.  I know it can't be rocket science.  Could someone out there please help us?
LulupcC
Same thing here.  TV  shuts
Same thing here.  TV  shuts off after approx. 5 to 10 seconds.   Not even giving me enough time to work with the menu or controls.......  Does anyone have an answer for this,  that doesnt cost as much as the TV????
Folks Please. I need model or
Folks Please. I need model or better yet chassis numbers on the RCA.
maddog
is any one know how to fix tv
is any one know how to fix tv or what lot of ? no fix
littleal
I have a 27 inch RCA
I have a 27 inch RCA television, Model no. 27V513T, chasis no. M134C
This unit shut off, intermittingly. I have troubleshooted it, and so far
have found no bad components. Well it obvious, I'm missing something.
Any comments or resolutions are welcome.
littleal,  On a set as this
littleal,  On a set as this one, you are most likly going to have to get a meter that has a hold feature, locate the main regulated b+ point in the main power supply and put the meter with the hold reading onto the b+ point and measure and monitor the main b+ supply to see if maybe the B+ may be causing the problem..  I have done this on a few sets as I was unaware of the problem and as it turned out the hold feature will hold and store the highest voltage that comes onto the b+ terminal as there may be an intermittant component making the b= go high intermittantly and causing the shutdown..  You also could have bad solder sonnections in the sweep power supply and or the horizontal sweep drive circuit.  Make sure you get a service manual for this set.  The manual is available HERE.  Good Luck, and let us all know how you made out with this set.
mike jones
my rca tv going off and on i
my rca tv going off and on i took my finger and upt over the sencer and took the remote out the room it still on now
mike jones
my rca tv going off and on i took my finger and put over the sencer and took the remote out the room
gottigirl
i have the same problem as
i have the same problem as above with my rca 27v520t set the tv comes on with sound and either turns right off or i get the wonderful rainbow spectrum or the picture comes in fine then just shuts off i spent 2hrs yesterday just turning it back on trying to watch a show how annoying
