Philips FTR 9965 E-Box
delboy
Help Needed Urgently
I have a Philips FTR 9965 E-Box Receiver i have no problems with it if i use my Plasma Tv.
But i wish to connect it to a Overhead Projector and project an image onto a 9ft screen to watch the World Cup Football Via the Monitor Out Socket.
But on doing so as soon as i connect the projector to it the E-Box goes into a standby mode.
Does anybody know who i can rectify this problem please.
Delboy
Valerio V
i have also the same e-box.
i have also the same e-box. now that my Philips 32 inch monitor (32FD9954) died, i'm temporarily using it on my Sony LCD monitor.
The box, after the first time it's turned on, will function. But then if you turn it off with the remote and turn it on later, it seems it will check and look for the Philips plasma connection, so that's why it turns off to standby. It can't find the Philips plasma circuitry.
Work around is that you have to manually turn the box off by pushing the power switch on the left side. Then when you want to turn it on, push it again manually.
So there's no more remotely turning it ON; only turning OFF....!!!!!
