hitachi projo 53fdx01b
1 post / 0 new
retired tv tech
I was unsoldering the convergence stk amps.after
unsoldering i checked the pins with needle nose plyers to see if they were loose.one pin i checked not sure if it was the pad,fell off pin.when i repaired a break in foil i would use copper wire to fix the break.not sure about this.
anyhelp appreciated,Edward
