Help with lost picture
DLea
My TV will turn on and the picture will be fine for about 10 minutes. After it has been on a few minutes, the picture will fade from clear to very grey, and then go completely black. The sounds still works fine even after the picture is lost. Can anyone give advice as to the nature of the problem and best option to cure or purchase another TV.
Since knowing the make and
Since knowing the make and model of your TV would be necessary to determine its value, I'd advise you to check out this article to help you decide to fix or replace: http://www.techlore.com/article/10602/
