hi i just got my psp about 1 month ago last night i was on the internet and it froze up so I tried to shut it off but it wouldnt and when it finaly did it wouldnt turn back on I tried pluging it in then takink the battery out and that in reverse and I tried without a game or memory stick so finaly I just took every thing out and left it out for the night now its the next mornig and it still wont turn and on when I charge it the charge light wont even come on I NEEEED HHHHHHHHHEEEEEEEEELLLPPPPPPPP
I'm having the same problem. I fell asleep with my PSP on last night and this morning it had turned itself off. It was on the charger the whole time so the battery shouldn't be drained. Anyway, it wont turn on now. I've taken out and reinserted the battery but I get no power. There is no charge light either when I plug up the adapter.
Any ideas?
Try Charging it all night and try a diffrent battery .
i was with my friend and my psp wouldnt play the game so i had to update it and i had to turn it off when it was updating and went home and when i got there i tried to turn it back on again to play it and it wouldnt come on but the power light would work so i charged it ower night and tried to turn it on in the morning and it still wouldnt work
HELP!!!!!!
That's weird. Did you have custom firmware? Because you might have bricked it on accident.
my psp will not turn on and nothing will happen so what should i do?
If you (or someone who did it for you) hacked your PSP to run custom firmware, google "PSP Brick Fix". I can tell you for sure you are going to need a "Pandora Battery" (google for instructions) and "Magic Memory Stick" making program (again google).
If your PSP is running boring Sony firmware (no hacks), then the only thing I can think of either the battery got overheated and it fried the board, or when you updated the firmware something happened to the battery/AC power and it stopped in the middle of updating, bricking the PSP.
I'm probably going to write an article on how to put custom firmware on PSPs (and methods of fixing any bricked normal PSPs) here soon, once I get some free time. Feel free to Message my account here and I'll try to help you out to the best of my knowledge.
My PSP stopped working all of the sudden, and thanks to my kid brother, I found out it was only that my charger fried... Glad he had a spare!
It died, or it stopped working because the charger was fried?
It was off for a few days, and when I tried to turn it on it didn't want to turn on again, guess the battery lost the initial charge.
Hmmm, that's actually really weird. Unless your battery was almost dead and you put it into standby, rather than shutting it down, that shouldn't happen after only a few days.
You might wanna invest in a spare battery.
My psp was charging (WHIEL I WAS ON THE INTERNET) then a whiEL later i noticed the power light was blinking green so i unpluged the charger and tried another outlet it still didn't charge. so i secretly tried my bro's charger and it charged so i figured the charger f***ing fried so i went to game stop and got a new charger for $15 i couldn't find the same modle charger but the gamestop charger works fine maby u r charger fried and the batterey ran out over night
that happend to me and i returned it but try putting the battery in front of the sun for 2 hours or keep charging it
The same thing happened to me, i was on the internet looking up so personal stuff >.> cough and it shut off and wont turn back on! i think my charger fried because it was plugged in during a thunder storm and the power surged twice
same here i was on the internet looking up anime! and it shut off and wouldnt turn back on, i had some problems back when my psp turned off but it turned back on. I think my charger fried cause it was plugged in the wall during a thunder storm and the power surged twice... ill see when i have a chance to use another psp charger, and ill probably get a psp battery too
When I was on my psp,my psp had said it was on low batteries.So I went to get the charger and plug it up to the psp.Everything was going okey until it said low batteries again when it was charging.So I checked everything and everything was set up right.So I did the whole process again.Now the charging light would not come back on.What should I do?
help mine is worst i accidentaly soldered all the legs in my CO4 part in the battery after making it pandora now it wont charge charge level is always 0% and it says CHARGING but charge level doesnt change...:(
Hey, I was playing Assassins Creed and all of the sudden the psp turned off. I thought the battery just died but it doesn't have a charge light. Any ideals?
my mom got me a model PSP-2006 over seas a few years ago and brought it back to the states, and it worked. she went on e vacation with her boyfriend and my sister. my sister played it all the way there and stopped playing it. we pulled it out the other day an it will not turn on. We tried a new charge a new battery a charger with higher volts. we had called sony and they said with this psp you need more or less than 5 volts. well we tried it and its still not working. What do you think is wrong with it???
my psp wont turn on at all i was playing it last night and it was fine then it had 2 bars left so i charged it for a long time it is a plug in charger and a bigger battery than the original battery but still a psp battery the light turned green and i still left it pluged in for a while then i unplugged it and put it in the psp and it wont turn on i dont know whats wrong please help its not mine!! please and thankyou
ok i have a psp 3001 and when i try to charge it won't turn on but when i use other peoples batteries it works and when they charge my battery it also works what do you thonk it is wrong with it and how can i fix it
this maybe the best answer youve had..... one step....let the battery drain and turn it back on again!!!!!!thats what used to heppen to my psp go that i lost...and tell me if it helped
my psp wont turn on but when i plug it in to the charger the green light comes on but it still wont turn on. what should i do?
i left mines chargering on the computer all night and it won't turn on and its my boyfirends what can i do...??? :(
my psp turned off due to low battery while i was playin pes...afta dat it has refused to turn on...not even showing any lite and wont charge.my battery chargd in anoda psp but stil my psp is stil dead...HELP PLEASE ITS ONLY 4MONTHS OLD-am usin firmware 5.00 and havnt downgraded or upgraded since d psp got hackd...along side my iso games-i play psx games on it-i nid ur help...tanx.
