I have a Phillips / Magnavox TV model# TS2746 C221, and the sound just quit working. Do you have any suggestions as to what I might repair or replace to fix this? All other functions are normal.
The sound just quit, Phillips/Magnavox TV model# TS2746 C221
Fri, 01/20/2006 - 10:23
Couple of solutions---Did u try the earphone jack to see if that works? Make sure the muting is not activated. Trace wire from speaker to ciruit board, could be bad solder connection--dirty or loose --Good luck---
Try the earphone , if the sound is good ; replace the speakers.If there is no sound , open carefully the TV, in the chassis you will found the sound IC chip who send sond to speakers. Test the resistors and capacitors around, if they are good change the IC Chip.
Thank you
Rusa
