Convergence Adjustment Problem
5 posts / 0 new
dnyara
I have a Panasonic Projection TV Model PT-53WX42F on the convergence adjustment with the blue I am not able to aline the top left, top right, bottom left, bottom center, bottom right. I can however aline the top center,left center, right center. Any clue as to what the problem might be. Thank You
zdave
you have a bad ic or 2 in the
you have a bad ic or 2 in the convergance circuit.
unless you know what you doing quit.
it lot of work to get them out and they can cost few bucks.
zdave
TechTony
I have a Panasonic 56" and
I have a Panasonic 56" and started the same problem just yesterday.  I could change the chips if that is the problem.  Could you detail which chip I need to change?  I have Blue intruding all over the screen.
jgomez123
I also have a Panasonic PT
I also have a Panasonic PT-53WX42F that is having convergence issues. I am looking for the Repair Manual. Does anyone have this available to download? And, where can I order the parts to do the repair?
Smitty357
I have been looking for the
I have been looking for the repair manual for some time myself. I have the PT-47WX53 which does not cover the PT-53WX42F. Some settings are the same but going by the information in it, my television will not align properly. Anyone could help this would be much appreciated. Thank you,
