DVD Player Skips
4 posts / 0 new
Trek
DVD Player Skips
I'm new at this... My DVD Player/Recorder "skips" while watching movies. Is this an easily rectified problem?
jed77
I have the same problem but a
I have the same problem but a clue I might add is that tipping the whole unit sometime makes it play correctly.My unit is a Toshiba dvd/vcr sd-v392su.
jed77
I found that my toshiba will
I found that my toshiba will not play an audio cd without also skipping as with a dvd.The tipping does at times work I think it might only indicate something like an misalignment ,however.
MM
I have this problem.
I have this problem. Sometimes I can get it to stop by simply pressing Stop and then after a moment, Play, or even by turning off the DVD player and then starting it again. When the problem still doesn't get corrected, I usually have to conclude that the problem is the DVD itself.
