I'm havinf a problem with my dvd player. I have a yellow triangle in the center that says pscan in it and my movies play double. one on the left side and one on the right. How do I turn this off? Memorex MVD2042
"pscan" is referring to the player's progressive scan feature. My guess would be that your television, or the input it is currently plugged in to, is not progressive scan capable. To correct this, all you need to do is disable the progressive scan feature.
To disable:
Turn off the DVD player
Locate small switch on back of player labeled "Progressive Scan"
To disable:
I would marry you if i could.
thanks loads
Dee
