Quasar TV/VCR squeals when playing a videotape
raindots
I didn't see any problem exactly like this one: my 7-year old Quasar TV/VCR combo often emits a high-pitched squeal while watching or rewinding or fast forwarding a VHS tape. Is this just a matter of needing to clean the VCR or does this mean it's only downhill from here?
Often noises like these are
Often noises like these are caused by weak belts that are slipping during normal use. It could be the drive belt, loading belt, or both. It also could be a worn video head drum bearing or misaligned antistatic brush.
Regardless, I wouldn't recommend you put any money into this TV. In the future, I never recommend combination units (any brand), as seperate devices usually cost less, give better performance, and maximize your flexibility. Plus, if the VCR breaks, the TV is still good.
