I have a 41" sony module #KP41EXR96 that I'm working on and I have POOR CONVERGENCE. I've checked IC1705 "STK4278" both 100uf25V caps "C1715" and "C1745". They all test fine. Please can someone give me a proceadure and drawing of the convergence board.
Clayton
POOR CONVERGENCE ON A SONY MODULE #KP41EXR96
Sat, 10/22/2005 - 14:10
i have a sony model KP-46WT510 that has convergence problem also 2 shadows blue on one side red on other is the adjustable or need repairing any help would be helpful the tv is only 3 years old
Bob, you have the common problem of the convergence IC's gone bad. If you have soldering experience or have any experience soldering and or working on solid state printed circuit boards, then you shoul be able to get these IC's and replace them. If you have no electronic experience, Please call a pro as this is not a job for the unexperienced. Good Luck, and let us know how you make out with this repair
do you know where i can get a wiring diagram showing the ics i can repair if i know which ones they are i do a lot of repairs on printed circuits in remote control cars pleasse let me know thanks bob
Semd me your E-mail addy and i will see what I can do.
[email protected] if you need any money for diagram please let me know i know they can cost and i will be more then glad to pay for it and thanks again for the help
Bob, I sent you the KP46WT500, it has the same chassis number. If I have it I will share the manual with you. Good Luck and let us know what you find.
larry i need to bring my tv from storage so i can work on it can i lay it on it's back in order to transport it or will this through the guns out of alignment please let me know thanks again bob
You really should not move or transport a projection TV on the side or the back but I have seen peeps do it that way and had no troubles and have see peeps do it that way and have lots of trouble.
can someone email me the service manual to my sony kp46wt510 thanks [email protected]
Can someone email me the service manual for kp-46wt510 for a sony
