I accidently leaned on the controller while wrestling with the dog. When I looked up I saw that the screen has blacked out in the center but there is still a 1/2" of picture around the outer edge and good sound. I went through the menu and video adjustments, caption locks, owners manual etc but no luck. I am connected to a satalite and have a second TV split off from this one and it works fine leading me to believe the controller was likely on the "TV" mode when I screwed it up. Would anyone have an idea as to what the problem is?
This could be your problem:
http://www.techlore.com/article/10692/
Check that out and post back with your results.
Well at noon it was still blacked out. I couldn't reach the plug so I cut the power on/off at the fuse box and it still was blacked out. I read and figured what Matt Whitlock came up with was likely the problem, but when I turned on the t.v. it worked fine? I don't know.
But thanks Matt, it likely was that.
Sincerely
Mike Smith
