I have a 55" Mitsubishi rear projection tv and the color is way off. We had surround sound installed yesterday and since then the only colors that are displayed are blue, yellow and brown. No red and green. I've tried everything to adjust the color and nothing helps. Any advice? It's driving me crazy!
Today, a resume simply isn’t enough to stand out among thousands of applicants. Go beyond with a JobFit Report.
Sounds to me like you have a device connected with component video, and the Pr(Cr) cable is loose of not properly connected. It's also possible that the Pr(Cr) and Pb(Cb) cables are reversed. If you posted a screenshot I may be able to tell you which.
Check the connections from your source device to the display and post back.
